force a object to revolve through another ann not cause conflicts
michael_adams236
Member Posts: 6 EDU
got it, thanks for the help ---
If you want to get the intersection of two parts, you probably want to use the Boolean feature.
For what you're doing, I'm assuming you just want to use Add, not Intersect. And merge scope means "what part do you want this feature to merge with?" Since you have that gray part over there, you need to explicitly tell Onshape you want your revolve to merge with the blue part.
