Lofting from rectangle to cylinder face creates a spiral. Trying to create a screwdriver tip.
ode_tujoy
Member Posts: 14 ✭
Hi there.
I'm making a purpose-built screwdriver but the tip is coming out funky.
Lofting from Plane 1 to the face of the extrude creates a spiral sort of twist.
Any way to correct for this to make it look more like a real screwdriver?
It works, and prints fine, just a little detail I'd like to learn from is all.
Thanks.
https://cad.onshape.com/documents/04904c49c4fd6273b89cc0e2/w/12ff00a3c50fe9087b983379/e/5d8f9b961d8691dbae24b5f1?renderMode=0&uiState=6553e54d0c6be107f89559f0
Thanks.
S1mon
Member Posts: 3,768 PRO
The easiest thing to do is split the circle in 4 places and have symmetric relations. This gives the loft command a clear place to connect the sharp corners of the rectangles. You can then tweak the exact dimensions/proportions of the splits to get the shape you want.Simon Gatrall | Product Development Specialist | Open For Work
2 -
wayne_sauder
Member, csevp Posts: 628 PRO
S1mon is correct although I would question if loft is the right tool to use for a screwdriver head.
https://cad.onshape.com/documents/e9bae502399e3411168feb8e/w/1ec0e768b12fbcc84686fd64/e/6f315fe685941080381ad650
2
https://cad.onshape.com/documents/bc449290e08116a9dae9b61a/w/cd849b214c6c741fdc305ea2/e/64efe06968467e936e0641ae
The loft idea was based on a video tutorial so I followed it.
But I like the idea of sketching the tip profile and remove-extruding that.
