Hole did not regenerate properly.
 jeffrey_gilley
                    Member Posts: 4 ✭
jeffrey_gilley
                    Member Posts: 4 ✭
            I have what should be a very simple drawing.  It is a 7.625 X 7.625 plate with two .56" diameter holes, .55" deep. One hole on each of the top left and right corners, 1.25" from top and
1.25" from the left and right side.  After placing the holes on the drawing and clicking the the GREEN  check mark I get a message, "Hole did not regenerate properly. No target part selected for holes."   Since I (think) I only have 1 part, the plate, that I placed the points on then set the holes on those points.  I also tried, "select mate connectors" from the hole drop down and get the same message.
  What am I missing/doing wrong?
Today is my first day using OnShape or any CAD program.  Trying to learn enough to do some DIY projects using a Plasma CNC table.
Thanks for your help.
             nick_papageorge_dayjob
                            Member, csevp Posts: 1,028 PRO
                    You need to have a solid in order to make a hole. Right now you only have a sketch. Extrude the sketch into a solid, then the holes will work. nick_papageorge_dayjob
 When you are all done with your part, you can right click on the face and select export as dxf/dwg for your plasma cutter.0
Forum Post Checklist
Link to original
https://cad.onshape.com/documents/d86c28a39c6c4f8572e19a78/w/3e50c1f08c403cdd3d1a6fff/e/93ed571e04dad6db03d1b04e?renderMode=0&uiState=6562460b2eb6563f229facfc
I recreated my original drawing, with my original - Hole did not generate properly , error,
Link to new
https://cad.onshape.com/documents/ad88895ee07e3c0c9ea45652/w/4a7ffd199cbe17e2d320e5ad/e/dfc425fca34bd9484b08b91e?renderMode=0&uiState=656244442eb6563f229fa69a
I am still not sure what I am doing/not doing right/wrong. I am working through the self paced education, but so far it has not helped me resolve this issue.
Any additional info would be appreciated.
