copy parts
bruce_resnicoff
Member Posts: 1 ✭✭
in General
How do I copy a part (or assembly) to a new document so that I can make changes without affecting the original? It's not clear in the help or tutorials sections how to do this.
I believe what you are searching for is called branching, you can see the docs on it here. However, if you are set on moving it to a new document, you can always right click the element, select `Copy to clipboard`, open your new document, hit the plus in the bottom left corner, and select `Paste tab`.
Best,
Mike
Note this will not copy the feature list used to create the part, just the part itself.
I want to put this part into another Part Studio. There are only two parts salvageable from design 1 and they are sufficiently complex I don't want to have to redraw them.
CADSharp - We make custom features and integrated Onshape apps! cadsharp.com/featurescripts 💎
OnShape - How to use 3D Model STEP Import Files to Design Parts Around (youtube.com)
