Link sharing does not make assembly simulation availible
shawn_crockershawn_crocker Member, OS Professional Posts: 892 PRO
This feels pretty undesirable.  Not sure if it is just me, but shouldn't we be able to spend a bunch of time creating a simulation and then link share it to a customer so they can also explore the tests interactively?  I guess my main problem with this lack of functionality is that the simulation tool does not have any other way of generating a report or something.  I will have to save screen printings and make a report entirely manually.  Maybe I am unaware of something?
  • eric_pestyeric_pesty Member Posts: 2,185 PRO
    I think simulation is available in publications so that might be a way around that limitation, it does seem like it should also be available in a link share though...
  • shawn_crockershawn_crocker Member, OS Professional Posts: 892 PRO
    @eric_pesty
    That back door was covered also.  link sharing the pub also gives no simulation view through a link share.
    @eric_pesty
    My bad... Missed that part...
  • GregBGregB Member Posts: 4 PRO
    You need to be signed into Onshape as a Pro or Enterprise user to see the "Show results" for a simulation, whether it is a link shared doc or Publication, or indeed any doc for which you have view-only permissions.
    Just to update this thread, it seems this issue is not actually intentional and has been labeled as a bug to be fixed.  :)
