How do I update the FeatureScript version of a tab in a document?
ZimCube
Member Posts: 3 ✭
In this document at V2, there are two Part Studio tabs, `Metric Midget Wrench Set` and `Bin Configurator`. If I hit "Show Code" for them I see the "Bin Configurator" tab is at an older FeatureScript version, 1963 versus 2180. How can I update that Part Studio to the latest library version?
Typically, if a Part Studio is behind on the Main, it will be automatically updated. Sometimes, if it is an old document, it will not be updated until the user enters the document, in which case they will be given a prompt asking if they want the document updated at this time. I'm not sure why Bin Configurator is still behind though. Maybe wait until the next release when they will batch update active documents and see if that changes things.
chadstoltzfus@premiercb.com
First, create a new branch from version V2. At that point you should immediately see a notification with the option to upgrade the FeatureScript in that new branch. After upgrading, you can merge that upgraded branch in instead of directly merging the version.
We prevent merging old versions directly into new branches because it could be a sneaky way of avoiding our typical upgrade process, which we perform on all active workspaces when we release every ~3 weeks. The workflow above of branching and upgrading before you merge ensures any necessary upgrades are not skipped.
