How to copy user sketch to another plane and extrude (Fixed)
sean_connor714
Member Posts: 6 ✭
Hey all,
I have a predefined user sketch on a default plane, and I'd like to essentially copy that user sketch to a feature script generated plane and extrude it from there.
Is something like that possible through feature script?
FeatureScript 2180;
import(path : "onshape/std/common.fs", version : "2180.0");
annotation { "Feature Type Name" : "Truss" }
export const truss = defineFeature(function(context is Context, id is Id, definition is map)
precondition
annotation { "Name" : "Slot Sketch", "Filter" : EntityType.FACE, }
definition.slot is Query;
annotation { "Name" : "Slot Wall Sketch", "Filter" : EntityType.FACE, }
definition.slotWall is Query;
annotation { "Name" : "Body Radius" }
isLength(definition.bodyRadius, LENGTH_BOUNDS);
opSphere(context, id + "sphere1", {
"center" : vector(0, 0, 0) * millimeter,
"radius" : definition.bodyRadius
var plane = createPlaneOnSphere(context, id + "pointPlane1", vector(0, 0, 0), definition.bodyRadius, vector(1, 0.5) * radian);
opExtrude(context, id + "slot", {
"entities" : definition.slotWall,
// Here I'd like to essentially copy the sketch the calculated plane above and extrude from there instead.
"direction" : evOwnerSketchPlane(context, {"entity" : definition.slotWall}).normal,
"endBound" : BoundingType.BLIND,
"endDepth" : definition.bodyRadius * 2
export function createPlaneOnSphere(context is Context, id is Id, sphereCenter is Vector, sphereRadius is ValueWithUnits, uv is Vector)
// Convert U & V (spherical coordinates) to Cartesian coordinates
println(uv[1]);
var x = sphereCenter[0] + sphereRadius.value * sin(uv[1]) * cos(uv[0]);
var y = sphereCenter[1] + sphereRadius.value * sin(uv[1]) * sin(uv[0]);
var z = sphereCenter[2] + sphereRadius.value * cos(uv[1]);
var pointOnSphere = vector(x, y, z);
// The normal vector is simply the vector from the center to the point on the sphere
var normalVector = normalize(pointOnSphere - sphereCenter);
println(pointOnSphere);
// Create the plane
var plane = opPlane(context, id + "plane1", {
"plane" : plane(pointOnSphere, normalVector)
return plane;
}}Thanks,
FeatureScript 2180; import(path : "onshape/std/common.fs", version : "2180.0"); annotation { "Feature Type Name" : "Truss" } export const truss = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Name" : "Slot", "Filter" : EntityType.FACE, } definition.slot is Query; annotation { "Name" : "Slot Interior", "Filter" : EntityType.FACE, } definition.slotInterior is Query; annotation { "Name" : "Body Radius" } isLength(definition.bodyRadius, LENGTH_BOUNDS); } { opSphere(context, id + "sphere", { "center" : vector(0, 0, 0) * millimeter, "radius" : definition.bodyRadius }); for (var i = 0; i < 4; i += 1) { println(i); var plane = createPlaneOnSphere(context, vector(0, 0, 0), definition.bodyRadius, vector(i / 2.0 * PI, PI * 0.75) * radian); opExtrude(context, id + i + "slot", { "entities" : definition.slot, "direction" : evOwnerSketchPlane(context, {"entity" : definition.slot}).normal, "endBound" : BoundingType.BLIND, "endDepth" : definition.bodyRadius * 2 }); opExtrude(context, id + i + "slotInterior", { "entities" : definition.slotInterior, "direction" : evOwnerSketchPlane(context, {"entity" : definition.slotInterior}).normal, "endBound" : BoundingType.BLIND, "endDepth" : definition.bodyRadius * 2, "startDepth" : definition.bodyRadius * -1, "startBound" : BoundingType.BLIND }); opTransform(context, id + i + "transform", { "bodies" : qUnion([ qCreatedBy(id + i + "slot", EntityType.BODY), qCreatedBy(id + i + "slotInterior", EntityType.BODY) ]), "transform" : transform(evOwnerSketchPlane(context, {"entity" : definition.slot}), plane) }); opBoolean(context, id + i + "union", { "tools" : qUnion([ qCreatedBy(id + "sphere", EntityType.BODY), qCreatedBy(id + i + "slot", EntityType.BODY) ]), "operationType" : BooleanOperationType.UNION }); opBoolean(context, id + i + "subtract", { "tools" : qCreatedBy(id + i + "slotInterior", EntityType.BODY), "targets" : qCreatedBy(id + "sphere", EntityType.BODY), "operationType" : BooleanOperationType.SUBTRACTION }); } }); export function createPlaneOnSphere(context is Context, sphereCenter is Vector, sphereRadius is ValueWithUnits, uv is Vector) { // Convert U & V (spherical coordinates) to Cartesian coordinates println(uv[1]); var x = sphereCenter[0] + sphereRadius.value * sin(uv[1]) * cos(uv[0]); var y = sphereCenter[1] + sphereRadius.value * sin(uv[1]) * sin(uv[0]); var z = sphereCenter[2] + sphereRadius.value * cos(uv[1]); var pointOnSphere = vector(x, y, z); // The normal vector is simply the vector from the center to the point on the sphere var normalVector = normalize(pointOnSphere - sphereCenter); println(pointOnSphere); var newPlane = plane(pointOnSphere * millimeter, normalVector); //var newPlane = opPlane(context, id + "plane1", { // "plane" : plane(pointOnSphere * millimeter, normalVector) //}); println(newPlane); return newPlane; }FeatureScript 2180; import(path : "onshape/std/common.fs", version : "2180.0"); annotation { "Feature Type Name" : "Truss" } export const truss = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Name" : "Slot", "Filter" : EntityType.FACE, } definition.slot is Query; annotation { "Name" : "Slot Interior", "Filter" : EntityType.FACE, } definition.slotInterior is Query; annotation { "Name" : "Body Radius" } isLength(definition.bodyRadius, LENGTH_BOUNDS); } { opSphere(context, id + "sphere", { "center" : vector(0, 0, 0) * millimeter, "radius" : definition.bodyRadius }); for (var i = 0; i < 4; i += 1) { println(i); var plane = createPlaneOnSphere(context, vector(0, 0, 0), definition.bodyRadius, vector(i / 2.0 * PI, PI * 0.75) * radian); opExtrude(context, id + i + "slot", { "entities" : definition.slot, "direction" : evOwnerSketchPlane(context, {"entity" : definition.slot}).normal, "endBound" : BoundingType.BLIND, "endDepth" : definition.bodyRadius * 2 }); opExtrude(context, id + i + "slotInterior", { "entities" : definition.slotInterior, "direction" : evOwnerSketchPlane(context, {"entity" : definition.slotInterior}).normal, "endBound" : BoundingType.BLIND, "endDepth" : definition.bodyRadius * 2, "startDepth" : definition.bodyRadius * -1, "startBound" : BoundingType.BLIND }); opTransform(context, id + i + "transform", { "bodies" : qUnion([ qCreatedBy(id + i + "slot", EntityType.BODY), qCreatedBy(id + i + "slotInterior", EntityType.BODY) ]), "transform" : transform(evOwnerSketchPlane(context, {"entity" : definition.slot}), plane) }); opBoolean(context, id + i + "union", { "tools" : qUnion([ qCreatedBy(id + "sphere", EntityType.BODY), qCreatedBy(id + i + "slot", EntityType.BODY) ]), "operationType" : BooleanOperationType.UNION }); opBoolean(context, id + i + "subtract", { "tools" : qCreatedBy(id + i + "slotInterior", EntityType.BODY), "targets" : qCreatedBy(id + "sphere", EntityType.BODY), "operationType" : BooleanOperationType.SUBTRACTION }); } }); export function createPlaneOnSphere(context is Context, sphereCenter is Vector, sphereRadius is ValueWithUnits, uv is Vector) { // Convert U & V (spherical coordinates) to Cartesian coordinates println(uv[1]); var x = sphereCenter[0] + sphereRadius.value * sin(uv[1]) * cos(uv[0]); var y = sphereCenter[1] + sphereRadius.value * sin(uv[1]) * sin(uv[0]); var z = sphereCenter[2] + sphereRadius.value * cos(uv[1]); var pointOnSphere = vector(x, y, z); // The normal vector is simply the vector from the center to the point on the sphere var normalVector = normalize(pointOnSphere - sphereCenter); println(pointOnSphere); var newPlane = plane(pointOnSphere * millimeter, normalVector); //var newPlane = opPlane(context, id + "plane1", { // "plane" : plane(pointOnSphere * millimeter, normalVector) //}); println(newPlane); return newPlane; }
