Creating a variable within a Skectch
I've tried to create a variable as instructed in the help but after I click the dimension tool between two point and then try to enter a variable name for this dimension like #pWidth it just show up red. Do I need to define that pWidth is a variable ahead of time.
I'm bit lost about what I'm doing wrong as there no numbers within the help to tell me if a previous set of instructions is required before I try to define a variable via #pWidth.
Thanks for any and all help in advance.
Shout of you can't get it to work and we'll go through an example.
having the same issue. I started with creating the variables. And then the sketch. Following the video tutorial and boom I cannot choose #HI. Or any other version I name it.
https://cad.onshape.com/help/Content/variable.htm#AssignedD
