Sweep cutter path through a cylinder
Kevin_GallichanKevin_Gallichan Member, pcbaevp Posts: 6 PRO
Hi, I want to create a cut shape that emulates a milling cutter path in the outer surface of a cylinder. The cutter path will rotate around the centre axis of the cylinder.
I can create a wrap shape that puts the cut into the cylinder  but this creates an angle between the edges/faces which would not be created by a milling cutter - it should have parallel sides.
Hop that makes sense.
Any tips ?
Thanks
