Solidworks to Onshape
Niklas_RyanNiklas_Ryan Member Posts: 1 ✭✭
I have been impressed so far with the ease of moving some of my Solidworks files into Onshape. You can tell they have put in the work to make it painless as possible.
I’m still doing some testing but I’m feeling more comfortable with it by the day.
I believe the biggest chore will be getting part numbers nailed down.
With that being said, does anyone have any lessons they learned along the way or helpful tips when migrating legacy CAD files into Onshape?
  • Konst_ShKonst_Sh Member Posts: 122 PRO
    There is an app in Onshape appstore that will translate all the metadata of SW files to Onshape properties:
  • billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,119 PRO
    I think you're going to find that OS can truly get the job done. Part numbers is a thing, but releasing parts is another.
    Most SW users have in their mind that a part is contained in a file. Parts usually end up in assemblies.
    Here there are part studios that contain parts. And should parts end up in assemblies? I believe so. Some here will disagree and will state that designing in a part studio is better than designing in an assembly. You'll need to figure out parts, part studios & assemblies and how to implement these into your company.
    I've been using OS for a long time and would never move back to a file based system. The cloud is the place to be, there are so many benefits to have a single database for all OS users. The controls that can be built into a monolithic structure is still being explored and will grow into capabilities that we haven't realized as of today.
  • adrian_vlzkzadrian_vlzkz Member, pcbaevp Posts: 302 PRO
    Make sure to implement a system where your "released" parts are contained within their own Document. In early development it might work to have multiple Parts/Assemblies in one document, but as they matured in your process it is better if they become independent.
    CAD Engineering Manager
  • MichaelPascoeMichaelPascoe Member Posts: 2,761 PRO
    edited December 2023
    Here is some more software that will help: SolidTranslate - a feature translation tool to convert (design intent / features) between SOLIDWORKS and Onshape. It's currently in closed beta.
    https://www.cadsharp.com/solidtranslate/
