When I try to sweep an error keeps showing up, can someone help me.
afalzate13 Member Posts: 46 PRO
I'm guessing this is the overhead hold down bar to a rollercoaster? And you're trying to create a sweeped extrusion?
https://cad.onshape.com/documents/1ce398f40fa2289c4f95591e/w/d953bb6b6050da34f416d7be/e/8148d1c3c4c57393c7218195?renderMode=0&uiState=65723e6cd735724c7fcb2bb1
1 -
martin_kopplow Member Posts: 828 PRO
Yes, that is possible. You need to use mates that allow a certain degree of movement by min/max values for the angle around the axis you want to rotate. Then you could grab the bar with the mouse and move it, even animate it, or you could use 'configurations' and define an open and a closed state to select from the configurations menu.There are very comprehensive tutorials on the OS site, and you can find them by using search terms like animate or configurations.0
https://cad.onshape.com/documents/b9708b23a7684e72da67e9fe/w/fb02b42645bec808c4c25af7/e/846ab645d9d9417928901bb7
here's the link
