How to think this shape
rodrigo_martinelli
Member Posts: 7 ✭
Hello all, i've been trying different approaches on how to solve this.
My limited experience on cad modeling did'nt allowed me to solve this in an efficient way.
I need to extrude "1" along "2" up to edge "3". The objective is to blend "1" to finish in a straight face. The purpose of this question is to get an understanding of how you got to the solution, rather than the solution itself.
Closest I came is thickening the gray shape to the desired amount and then intersecting it with "1" but the result is unprolix.
MichaelPascoe
Member Posts: 2,687 PRO
Hi @rodrigo_martinelli,
Loft will be a good tool for this. Alternatively you could use Fill. But Loft with guides will probably be the best approach.
If you get stuck, please share a link to your model and we can help you out.
Also, the Learning Pathways are some of the best ways to learn Onshape.
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴0
For reference.. Loft 4 is the flat orange edge, Sketch 12 is the lower edge, 11 and 15 are the twin vertical curves..
