Sheet Metal: Flat view tab not showing
martin_kopplowmartin_kopplow Member Posts: 828 PRO
I noticed that the flat view tab is sometimes not available, after I open or switch to a part studio tab with a sheet metal model in it. Everything looks as usual, only the small tab with the unfolded icon on the right side of the model window isn't there. All other tabs are. When I sign off / sign in and open it again, it comes back.
Is that a bug or does it serve a reason?
  • glen_dewsburyglen_dewsbury Member Posts: 1,061 PRO
    Seems to be a bug that I see from time to time. Refresh browser seems to bring it back.
  • _anton_anton Member, Onshape Employees Posts: 461
    If it appears after you reload, it may be a bug. Could you check your browser console when this happens? And contact support with the details so that this gets flagged for us to investigate.
  • martin_kopplowmartin_kopplow Member Posts: 828 PRO
    Okay, next time I see that, I'll check.
