Version or Release
Mike_JohnsonMike_Johnson Member Posts: 2
Merged existing part in new assembly. Why does the existing part that was released go to a new version?
  • adrian_vlzkzadrian_vlzkz Member Posts: 272 PRO
    Versions are per Document, not per Part. If you want the Part to maintain it's Version, it would have to be in it's own Document
    CAD Engineering Manager
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 945 PRO
    edited December 2023
    Is the part studio and assembly in the same document? If the part in question is "released" to a number or letter rev, you can right click on the part in the asm feature tree to set it to releases (the triangle) in the version graph section. Then the asm will have the officially released part, and if the entire document gets a new version, the asm will still reference the "released" revision.
    Version = whole document
    Revision (release management in Professional and Enterprise plan) = is per part, per asm, or per 2d drawing.
