Moving (re-locationg) a complete title block.
Gerard_Boterman
Member Posts: 26 ✭✭
I have an A3 template and wanted to make this into an A2 template.
Doing so, my A3 template got an A2 border added, while my title block moved outside the border to the right.
When I select all entities and try to move this, only one entity of my title block moves. (my title block has got text, line and image entities)
I tried using mouse select + Alt, mouse select + shift, mouse select + Ctrl, nothing works. I can copy and paste. but have no control over there the new block is pasted.
There is no transform option in the menu.
Any help is welcome. Thanks, Gerard
The title block is unlocked. A
With any luck someone will give a better description and method than I'm describing. Haven't done personalized drawing templates for a while.
I am also looking for a solution for this
