problem with loft
in Drawings
I am trying to implement a simple loft , using two sketches with bezier line contours in parallel planes.
It happens that when I see the loft edit parameters, one is selected as Faces of .. and the other as Vertices of ...
What am I doing wrong ?
You can open up the selections and 'add' extra selections to the group. see screengrab
If you could share your document we could take a closer look
