problem with loft
jure_zaninovichjure_zaninovich Member Posts: 3
I am trying to implement a simple loft , using two sketches with bezier line contours in parallel planes.
It happens that when I see the loft edit parameters, one is selected as Faces of .. and the other as Vertices of ...
What am I doing wrong ?
  • GWS50GWS50 Member Posts: 455 PRO
    I'm not sure but it looks like you may have several sketches visible which may be preventing you from selecting the correct items to loft.
    You can open up the selections and 'add' extra selections to the group. see screengrab
    If you could share your document we could take a closer look
  • jure_zaninovichjure_zaninovich Member Posts: 3
    edited December 2023
    also note that "Guides and continuity" is void , nothing is selected, nothing makes a difference.
    thanks @GWS50 . will take a look using your input.
    for now what I have found is that splines produce faces ( OK for Loft )
    while bezier curves produce vertices , which cause the problem shown.
    is there a way to produce faces while using bezier curves ?
    are the statements above correct ?
    BTW , I am working on a simplified design so that I can share it with all of the community.
    thanks @GWS50
