Tutorial, Step Stool, Step 8, extrude/remove or pocket leaves a thin wall
ali_e280
Member Posts: 10 ✭
Hi,
I'm trying to complete the the step stool exercise. The instructions are to create on offset on the face and use extrude/remove to create a 5 mm indent. When I apply the remove extrude, I get an unexpected thin wall. This thin wall prevents the shell step following this step.
SKETCH
EXTRUDE OPTIONS
PART WITH THIN WALL
What step am I missing here?
Thanks,
Ali
_anton
Member, Onshape Employees Posts: 525
Because the sides of the part are drafted (at a nonzero angle with respect to the vertical), and you're extruding straight down, you'll get a really thin wall with a triangular cross-section.1
Thank you for the explanation.
