How to convert a boolean value to integer
sam_samasam_sama Member Posts: 2
I've created a configuration checkbox. I want to use the integer value of this boolean checkbox configuration. Is there any function that will return 1/0 for true/false boolean values?
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,248 image
    The expression
    myBoolean ? 1 : 0
    should work.
    The expression
    myBoolean ? 1 : 0
    should work.
