Sketch inside part always results in hidden lines
thomas_harrison627
Member Posts: 1 ✭
I am creating a sketch to use in a revolve cut on a part. In the sketch none of the lines are construction. When I finish the sketch any lines that intersect the part become construction, preventing me from using them in the revolve cut. I've created a simple part to demonstrate this. https://cad.onshape.com/documents/0b3fa9eb66c32cf0e01a17ba
wayne_sauder
Member, csevp Posts: 630 PRO
The lines are not construction. There are other faces in the way preventing you from selecting the sketch faces. Hide your part and then you will be able to select the sketch faces.0
The sketch can be selected from the feature tree as well,
https://cad.onshape.com/documents/78009a064734a75976487f88/w/7361410b0f2f6bbf9367afdf/e/65c90149c67da559bcd40023
