Mute objects through featurescript
eric_ma454eric_ma454 Member Posts: 14
Is there any way to mute lines/sketches created in a featurescript, or interacted with a featurescript? After instantiating many parts and creating sketches, there are a lot of construction lines and sketch planes left over that I would like to remove or hide.
Thanks,
Eric
AguaClara Cornell
  • kevinhickersonkevinhickerson Member, Developers Posts: 1 PRO
    But how? How do you delete a cruve created with line(...,...) for example?
  • _anton_anton Member, Onshape Employees Posts: 476
    Example:
    fCuboid(context, id + "cuboid1", {
        "corner1" : vector(0, 0, 0) * inch,
        "corner2" : vector(1, 1, 1) * inch
    opDeleteBodies(context, id + "deleteBodies1", {
        "entities" : qCreatedBy(id + "cuboid1", EntityType.BODY)
    This creates a cube and then deletes it. Note that the first call has id + "cuboid1" and that id is used in a qCreatedBy query to then delete the geometry.
