How to close a duct?
willian_tamagi
Member Posts: 12 ✭
Hello friends,
Is there any way to kind of close a duct that I have the start part and the end part, I just need to "close" this path? I tried the sweep feature but didn't work because the parts don't have the same size and they aren't aligned.
Document: https://cad.onshape.com/documents/d5c3e16a5198a123e5d41be6/w/25a5b91e536b021811b121cd/e/031345740e2222a84ddce048?renderMode=0&uiState=658f229383b3106c15ac1f61
wayne_sauder
Member, csevp Posts: 628 PRO
@willian_tamagi
I believe the loft tool will get you there, use guides to help control the shape.1 -
martin_kopplow
Member Posts: 1,078 PRO
This one's a bit tricky, for the profiles are a bit odd, but it's feasible when using the derive feature, then cut away the middle part and replace by a loft:
It might be better to remove all the unnecessary features first: Tangencies will be easier to get right, then.
1
