Input is a circle and a radius. Script's supposed to create a new circle, perpendicular to the first
nir_naronnir_naron Member Posts: 26 EDU
rOnshape - Trying to learn FeatureScript Love it so far I know there are probably too many mistakes in my code for you to note them all but any help would be appriciated a ton More in comments
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,979 image
    edited January 2024
    FeatureScript 2221;
    import(path : "onshape/std/common.fs", version : "2221.0");
    annotation { "Feature Type Name" : "My Feature" }
    export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
            annotation { "Name" : "Circle", "Filter" : GeometryType.CIRCLE, "MaxNumberOfPicks" : 1 }
            definition.circle is Query;
            annotation { "Name" : "Rad" }
            isLength(definition.radius, LENGTH_BOUNDS);
            const circle = evCurveDefinition(context, {
                    "edge" : definition.circle
            const sketch = newSketchOnPlane(context, id + "sketch1", {
                    "sketchPlane" : plane(circle.coordSystem.origin, circle.coordSystem.xAxis, circle.coordSystem.zAxis)
            skCircle(sketch, "circle", {
                    "center" : vector(0, 0) * meter,
                    "radius" : definition.radius
            skSolve(sketch);
