Double Threaded Tube - Hole Feature Failure
Nath_McC
Member Posts: 135 PRO
Hi All,
I have a 100mm long part, which is a bit of a tube (or can be a bar). It has 25mm of right-hand thread on one side and 25mm of left-hand thread on the other.
I currently have an issue using the hole feature. I cannot go through all with the drill and then use the feature again on the other side as the drill hole is already there, and essentially, there is no material to remove. In SolidWorks, I would use the cosmetic thread feature to achieve this.
I would like one call out to be dia 8.5 thru, M10X1.5 RH, depth 25 and the other just to be M10X1.5 LH, depth 25
I have a workaround where I half the drill depth and take 0.1mm off, so 49.9mm in this case, but it leaves a little "V" where the drill tip ends and the callouts look poor.
Would anybody have any solutions?
https://cad.onshape.com/documents/58785ba5e4466167a3ab62db/w/44240a9e6da406118bea177d/e/71dc0b0660dafde4e57588cd?configuration=List_dFYSwtPDwLAK5f=Default&renderMode=0&rightPanel=configPanel&uiState=6593fb83f362903964d421d1
Twitter: @BryanLAGdesign
You drilled and tapped to the same depth, then added a thru-hole feature.
Onshape support has logged this as an improvement request as well.
