Intersection between Circle and Ellipse
nir_naronnir_naron Member Posts: 26 EDU
Input is an Ellipse, my code generates a circle that intercects the ellipse exactly two times (its the smalles enclosing circle). How can I get the value of said two intersection points?
Sorry for messy code
FeatureScript 2221;
import(path : "onshape/std/common.fs", version : "2221.0");
annotation { "Feature Type Name" : "Elliptical Helix" }
export const EllipticalHelix = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
        //qGeometry(definition.Ellipse is Query, GeometryType.OTHER_CURVE);
        annotation { "Name" : "Ellipse", "Filter" : EntityType.EDGE, "MaxNumberOfPicks" : 1 }
        definition.Ellipse is Query;
        //annotation { "Name" : "Number of Turns"}
        //isInteger(definition.NumTurns, POSITIVE_REAL_BOUNDS);
        annotation { "Name" : "Circle", "Filter" : EntityType.EDGE, "MaxNumberOfPicks" : 1 }
        definition.Circle is Query;
        // Define the function's action
        var sketchId = id + "sketch";
        var Ellipse = definition.Ellipse;
        var Circle = definition.Circle;
        var Center = evApproximateCentroid(context, {"entities" : Ellipse});
        var BigRad = evCurveDefinition(context, {"edge" : Ellipse})["majorRadius"];
        //var TwoDCenter = sort(Center, function(a,b){return(b-a);});
        //println(resize(Center,2));
        var sketchPlane = evOwnerSketchPlane(context, { "entity" : Ellipse });
        var cSys = planeToCSys(sketchPlane);
        var sketchPlane2 = plane(Center*meter, cSys.zAxis);
        var sketch1 = newSketchOnPlane(context, sketchId, { "sketchPlane" : sketchPlane2 });
        skCircle(sketch1, "circle1", {
                "center" : vector(0, 0)*meter,
                "radius" : BigRad});
        skPoint(sketch1, "point1", {
                "position" : vector(0*meter, BigRad)});
        //definition.point1 is Query;
        //var point1 = definition.point1;
        //println(point1);
        opHelix(context, id + "helix1", {
                "direction" : sketchPlane2["normal"],
                "axisStart" : Center,
                "startPoint" : point1,
                "interval" : [0, 10],
                "clockwise" : true,
                "helicalPitch" : 0.1 * inch,
                "spiralPitch" : 0 * inch
        skSolve(sketch1);
        println("haha");
//qGeometry(qBodyType(qEntityFilter(seed1_REPLACE_ME, EntityType.EDGE), BodyType.WIRE), GeometryType.CIRCLE)
  • _anton_anton Member, Onshape Employees Posts: 524 image
    Looks like sketchEntityQuery(sketchId, EntityType.VERTEX, "point1")
  • nir_naronnir_naron Member Posts: 26 EDU
    Cool. What should I put under "sketchEntityId"?
    Allright,
    var point1 = sketchEntityQuery(id + "sketch1", EntityType.VERTEX, "point1");
    seems to work. But it doesn't really contain the point's values, so I can't really use it for the Helixe's Start Point.
    evVertexPoint(context, { vertex: point1 })
    It isn't working.
    Error:
    </code>@evVertexPoint: CANNOT_RESOLVE_ENTITIES</pre><span><br>Code:<br><pre class="CodeBlock"><code>        skPoint(sketch1, "point1", {
            println(evVertexPoint(context, {"vertex" : point1}));
    Thanks a lot for your help
    Code:
    Check that the query resolves to something - easiest way is with debug(context, myQuery);
    debug: Query resolves to nothing
    What am I doing wrong?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,979 image
    That freaks me out having skSolve after opHelix - always put it straight after all the sketch creation operations - if you put the debug before skSolve then that's your problem.
            skSolve(sketch1);
            evVertexPoint(context, { vertex: point1 });
            debug(context, point1);CODE:
    ERROR:@evVertexPoint: CANNOT_RESOLVE_ENTITIES
    All I want is to use point1 as a Start Point for a Helix. How can I do that?
    <br><br><br>
    edited January 2024
    It was your id in sketchEntityQuery - just copy/paste this code:
    FeatureScript 2221;
        precondition
            definition.ellipse is Query;
            definition.circle is Query;
            var ellipse = evCurveDefinition(context, {
                    "edge" : definition.ellipse
            var center = ellipse.coordSystem.origin;
            var bigRad = ellipse.majorRadius;
            var sketchPlane = plane(ellipse.coordSystem);
            var sketch1 = newSketchOnPlane(context, sketchId, { "sketchPlane" : sketchPlane });
                        "center" : vector(0, 0) * meter,
                        "radius" : bigRad
                        "position" : vector(0 * meter, bigRad)
            skSolve(sketch1);
            var point1 = evVertexPoint(context, {
                    "vertex" : sketchEntityQuery(sketchId, EntityType.VERTEX, "point1")
            debug(context, point1, DebugColor.RED);
                        "direction" : sketchPlane.normal,
                        "axisStart" : center,
                        "clockwise" : true,
    I've edited the above ^^ to make it simpler. Question: do you even need the sketch?
    Here's a super-simplified version of the same thing:
    FeatureScript 2221;
        precondition
                        "direction" : ellipse.coordSystem.zAxis,
                        "axisStart" : ellipse.coordSystem.origin,
                        "startPoint" : toWorld(ellipse.coordSystem, vector(0 * meter, ellipse.majorRadius, 0 * meter)),
                        "clockwise" : true,
    This works, thanks a lot.
    I don't really need the sketch. What I'm trying to do is write a script that receives an ellipse and a hight as inputs and outputs an elliptical helix matching them. I plan on doing this using the Projected Curve tool.
    Link to document. Check out the Part Studio named "Goal".
    https://cad.onshape.com/documents/6e86fb25b6b8f98a9f75d61f/w/4ed281d19b48cdb345ec86ed/e/12a0d3a6f8e2817aba5b2e3d?renderMode=0&uiState=6597e1949a15484af8f96795
    I managed to write a script that gets an ellipse as an input and creats a circle that fully encloses said ellipse. I was hoping to be able to just feed that into OnShape's Helix feature instead of working with opHelix. Is there a way to do that? If not, how would you reccomend getting this done with opHelix?
    I am very new to FeatureScript. Many thanks
    You should use "op" functions always - plus there are always easier ways of doing things, but that comes with experience. Here is what you need:
    FeatureScript 2221;
    annotation { "Feature Type Name" : "Elliptical helix" }
        precondition
            opHelix(context, id + "helix", {
                        "startPoint" : toWorld(ellipse.coordSystem, vector(0, 1, 0) * meter),
                        "clockwise" : true,
            opTransform(context, id + "transform", {
                        "bodies" : qCreatedBy(id + "helix", EntityType.BODY),
                        "transform" : scaleNonuniformly(ellipse.majorRadius.value, ellipse.minorRadius.value, 1, ellipse.coordSystem)
    FeatureScript 2221;
        precondition
                        "clockwise" : true,
    Awesome. Thanks a lot. I think I managed to wrap my head around it.
     I would be curious to see how you would go about doing this with the Projected Curve approach (See the part studio named “Goal”).
    Plus, how can I add a menu to switch feature-input types? Same way the Helix feature can receive either a circle or an axis or a face, and the Extrude feature can either be a New or an Add etc…
