Intersection between Circle and Ellipse
nir_naron
Member Posts: 26 EDU
Input is an Ellipse, my code generates a circle that intercects the ellipse exactly two times (its the smalles enclosing circle). How can I get the value of said two intersection points?
Sorry for messy code
FeatureScript 2221;
import(path : "onshape/std/common.fs", version : "2221.0");
annotation { "Feature Type Name" : "Elliptical Helix" }
export const EllipticalHelix = defineFeature(function(context is Context, id is Id, definition is map)
precondition
//qGeometry(definition.Ellipse is Query, GeometryType.OTHER_CURVE);
annotation { "Name" : "Ellipse", "Filter" : EntityType.EDGE, "MaxNumberOfPicks" : 1 }
definition.Ellipse is Query;
//annotation { "Name" : "Number of Turns"}
//isInteger(definition.NumTurns, POSITIVE_REAL_BOUNDS);
annotation { "Name" : "Circle", "Filter" : EntityType.EDGE, "MaxNumberOfPicks" : 1 }
definition.Circle is Query;
// Define the function's action
var sketchId = id + "sketch";
var Ellipse = definition.Ellipse;
var Circle = definition.Circle;
var Center = evApproximateCentroid(context, {"entities" : Ellipse});
var BigRad = evCurveDefinition(context, {"edge" : Ellipse})["majorRadius"];
//var TwoDCenter = sort(Center, function(a,b){return(b-a);});
//println(resize(Center,2));
var sketchPlane = evOwnerSketchPlane(context, { "entity" : Ellipse });
var cSys = planeToCSys(sketchPlane);
var sketchPlane2 = plane(Center*meter, cSys.zAxis);
var sketch1 = newSketchOnPlane(context, sketchId, { "sketchPlane" : sketchPlane2 });
skCircle(sketch1, "circle1", {
"center" : vector(0, 0)*meter,
"radius" : BigRad});
skPoint(sketch1, "point1", {
"position" : vector(0*meter, BigRad)});
//definition.point1 is Query;
//var point1 = definition.point1;
//println(point1);
opHelix(context, id + "helix1", {
"direction" : sketchPlane2["normal"],
"axisStart" : Center,
"startPoint" : point1,
"interval" : [0, 10],
"clockwise" : true,
"helicalPitch" : 0.1 * inch,
"spiralPitch" : 0 * inch
skSolve(sketch1);
println("haha");
//qGeometry(qBodyType(qEntityFilter(seed1_REPLACE_ME, EntityType.EDGE), BodyType.WIRE), GeometryType.CIRCLE)0
seems to work. But it doesn't really contain the point's values, so I can't really use it for the Helixe's Start Point.
Error:
</code>@evVertexPoint: CANNOT_RESOLVE_ENTITIES</pre><span><br>Code:<br><pre class="CodeBlock"><code> skPoint(sketch1, "point1", { "position" : vector(0*meter, BigRad)}); var point1 = sketchEntityQuery(id + "sketch1", EntityType.VERTEX, "point1"); println(evVertexPoint(context, {"vertex" : point1}));Thanks a lot for your helpskPoint(sketch1, "point1", { "position" : vector(0*meter, BigRad)}); var point1 = sketchEntityQuery(id + "sketch1", EntityType.VERTEX, "point1"); println(evVertexPoint(context, {"vertex" : point1}));<br><br><br>FeatureScript 2221; import(path : "onshape/std/common.fs", version : "2221.0"); annotation { "Feature Type Name" : "Elliptical Helix" } export const EllipticalHelix = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Name" : "Ellipse", "Filter" : EntityType.EDGE, "MaxNumberOfPicks" : 1 } definition.ellipse is Query; annotation { "Name" : "Circle", "Filter" : EntityType.EDGE, "MaxNumberOfPicks" : 1 } definition.circle is Query; } { var sketchId = id + "sketch"; var ellipse = evCurveDefinition(context, { "edge" : definition.ellipse }); var center = ellipse.coordSystem.origin; var bigRad = ellipse.majorRadius; var sketchPlane = plane(ellipse.coordSystem); var sketch1 = newSketchOnPlane(context, sketchId, { "sketchPlane" : sketchPlane }); skCircle(sketch1, "circle1", { "center" : vector(0, 0) * meter, "radius" : bigRad }); skPoint(sketch1, "point1", { "position" : vector(0 * meter, bigRad) }); skSolve(sketch1); var point1 = evVertexPoint(context, { "vertex" : sketchEntityQuery(sketchId, EntityType.VERTEX, "point1") }); debug(context, point1, DebugColor.RED); opHelix(context, id + "helix1", { "direction" : sketchPlane.normal, "axisStart" : center, "startPoint" : point1, "interval" : [0, 10], "clockwise" : true, "helicalPitch" : 0.1 * inch, "spiralPitch" : 0 * inch }); });FeatureScript 2221; import(path : "onshape/std/common.fs", version : "2221.0"); annotation { "Feature Type Name" : "Elliptical Helix" } export const EllipticalHelix = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Name" : "Ellipse", "Filter" : EntityType.EDGE, "MaxNumberOfPicks" : 1 } definition.ellipse is Query; } { var ellipse = evCurveDefinition(context, { "edge" : definition.ellipse }); opHelix(context, id + "helix1", { "direction" : ellipse.coordSystem.zAxis, "axisStart" : ellipse.coordSystem.origin, "startPoint" : toWorld(ellipse.coordSystem, vector(0 * meter, ellipse.majorRadius, 0 * meter)), "interval" : [0, 10], "clockwise" : true, "helicalPitch" : 0.1 * inch, "spiralPitch" : 0 * inch }); });I don't really need the sketch. What I'm trying to do is write a script that receives an ellipse and a hight as inputs and outputs an elliptical helix matching them. I plan on doing this using the Projected Curve tool.
Link to document. Check out the Part Studio named "Goal".
https://cad.onshape.com/documents/6e86fb25b6b8f98a9f75d61f/w/4ed281d19b48cdb345ec86ed/e/12a0d3a6f8e2817aba5b2e3d?renderMode=0&uiState=6597e1949a15484af8f96795
I managed to write a script that gets an ellipse as an input and creats a circle that fully encloses said ellipse. I was hoping to be able to just feed that into OnShape's Helix feature instead of working with opHelix. Is there a way to do that? If not, how would you reccomend getting this done with opHelix?
I am very new to FeatureScript. Many thanks
FeatureScript 2221; import(path : "onshape/std/common.fs", version : "2221.0"); annotation { "Feature Type Name" : "Elliptical helix" } export const EllipticalHelix = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Name" : "Ellipse", "Filter" : EntityType.EDGE, "MaxNumberOfPicks" : 1 } definition.ellipse is Query; } { var ellipse = evCurveDefinition(context, { "edge" : definition.ellipse }); opHelix(context, id + "helix", { "direction" : ellipse.coordSystem.zAxis, "axisStart" : ellipse.coordSystem.origin, "startPoint" : toWorld(ellipse.coordSystem, vector(0, 1, 0) * meter), "interval" : [0, 10], "clockwise" : true, "helicalPitch" : 0.1 * inch, "spiralPitch" : 0 * inch }); opTransform(context, id + "transform", { "bodies" : qCreatedBy(id + "helix", EntityType.BODY), "transform" : scaleNonuniformly(ellipse.majorRadius.value, ellipse.minorRadius.value, 1, ellipse.coordSystem) }); });I would be curious to see how you would go about doing this with the Projected Curve approach (See the part studio named “Goal”).
Plus, how can I add a menu to switch feature-input types? Same way the Helix feature can receive either a circle or an axis or a face, and the Extrude feature can either be a New or an Add etc…
