8020 Extrusion Frame, Not able to generate the composite Part
SANJRSANJR Member Posts: 8 EDU
Hi Everyone,
I have assembled a frame structure for a custom built machine. With the current features I find it difficult to assemble the as easy i have seen in the videos earlier. This could be due to the complexity of the design which i have. And i am also unable to generate a cut list. An error message is popped as ¨Failed to find frame start and end faces¨. What could be the reason for this message? Any insights on how to detect and solve this issue .......
  • glen_dewsburyglen_dewsbury Member Posts: 1,211 PRO
    edited January 2024 Answer ✓
    Found there was some kind of problem with extrude on vertical legs. Changed to a move face.
    Did you window select all parts for the cut list? Maybe something not a frame was selected.
     I changed to check box for select all frames. This not only gets all frames but excludes anything that's not. If you need any other items they can be individually if they are valid.
    BTW. Since I started using frames I've always used the move face to stretch items. Just seamed right and simple to use. So I've never looked into whether an extrude is considered valid.
    https://cad.onshape.com/documents/dede96d6108b03b7f1b481fe/w/a327bdac994fcd925499583c/e/1f63c7d79fd3c072e6b72753
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 365 image
    Please provide a link to public doc so we can see what you are trying…
  • SANJRSANJR Member Posts: 8 EDU
    Hi,
    Here is the LINK of the document https://cad.onshape.com/documents/d48256c42527ddb64198b933
    glen_dewsbury,
    Thanks that solves the issue.
    Not sure whether i can post one more issue for the same frame. But if solved that would be appreciable.
    Perpedicular frame of length 125 mm was supposed to be matched. However as shown below, in the frame window the ¨limit frame ends¨ option selected the ¨Parts to trim to¨ option thereby the section is taking the profile of the mating frame and the length is shown as 137.32 mm.
    Is there any other way that i could use plz......
    An aside. You may want to disable sketch imprinting on some of your sketches. Makes selection of items behind easier.
    In the limit frame ends you selected a part instead of a surface as the limiting factor. This is what causes the new frame t follow contours of selected part instead of intended but joint.
