Resizing the text of a dimension in a sketch
brendan_martin531
Member Posts: 3 EDU
I'm a middle school engineering teacher rolling out Onshape Education Enterprise this fall with my students. Quick question- is there a way to make the dimension numbers bigger in a sketch? The numbers are somewhat small and in trying to take screenshots to support struggling students, I'm hoping to make them more readable.
A couple of alternatives you could try:
100% (default) zoom:
200% zoom:
Alternatively, you can make the window smaller and take a window screenshot (Alt Prt Sc on Ubuntu, not sure on other operating systems):
This will get you the larger size of the dimension numbers relative to the overall size of the image without making the 3D graphics area fuzzy.
I've used the browser zoom feature when presenting in person to make it easier to see the whole UI for people sitting far away from the projector. It might also be a good idea if you're presenting to an inexperienced audience on a video call so that it's possible to see/read all of the content on the screen even if they are using a low-resolution monitor (or if only a fraction of the screen shows your video feed, such as in zoom). Although, if you're sharing a single window, resizing it to be smaller might also work (but I haven't tried it, since I prefer sharing my whole desktop).
I hope this helped!
It would be really nice if the default text size could be changed and have it apply to both the screen and prints.
It's that simple 😀
your welcome~
