When I try and export a design (converting it to an STL file) it exports it as a PDF not as an STL
gareth_adeneygareth_adeney Member Posts: 2
Could someone advise me what I'm doing wrong, please.
  • ImpulsePDImpulsePD Member Posts: 8 PRO
    I assume you're selecting "STL" as the format when you export? Can you share a copy of your file?
  • Roberto_VerduciRoberto_Verduci Member Posts: 29 ✭✭
    Hi,
    are you sure you are running the export command from the part and not from the drawing? If I try to export a part I don't see the PDF option
