Rounding corners..lossless
stephen_motewstephen_motew Member Posts: 4
Hi. I have created a sketch to specific measurements that include a distance to the apex of a rounded corner.  When rounding the corner (either in sketch or extruded fillet) there is loss of the measurement from the initial rectangular dimensions and I was wondering how to create the correct distance to the apex of the rounded corner.  Example: Create a rectangle 20mm x 30mm, which matches the final dimension I need, then rounding the corner I 'lose' that distance and want the apex of the corner to match to original 20mmx30mm dimensions.  Hope this makes sense.
  • glen_dewsburyglen_dewsbury Member Posts: 1,111 PRO
    Not sure what the problem is. hw are you drawing the rectangle and dimensioning it?
    This sample uses a centered rectangle with dimensions on the fly with a fillet at the corners.
    Unless you are dimensioning the rectangle by selecting the sides after.
    https://cad.onshape.com/documents/f74bee447f89826d0f600190/w/76703c3d6a458ef733252579/e/889ec5dbda3b7cd4c912a3e9
  • stephen_motewstephen_motew Member Posts: 4
    Thank you I should have been more clear. I need specific dimensions from the apex of the smoothed (filleted) corners as my actual object is a trapezoid.  I need the cross corner distance which from the initial sketch is 20 mm, I need the roudned corner apex to apex distance to also be 20mm.  When fillet is created it shortens this distance.  Hope that helps make some sense.
    @stephen_motew
    Can you make your document public and share a link. Easier sometimes to see what's going on.
