Drawing BOM and view linked to different assembly configurations
jonathan_moore473
Member Posts: 4 PRO
I’m running into an issue with drawings. I have a drawing of an assembly, and the assembly has configurations. I’d like to be able to update the drawing based on which configuration I have selected. Right now, when I right click and change configuration of the assembly in the drawing, only the drawing views update and the BOM table does not. I can right click it and update the BOM individually, but these need to be linked.
How can I make it where the BOM and drawing views are always linked to the same configuration, so I only have to select the configuration once?
