Twist along path - Sweep
josh_o_connell
Member Posts: 2 ✭
Hi guys,
I'm just curious as to what is the best way to achieve a twist in a sweep profile?
I am trying to take a hexagon, extrude/sweep it 20mm and twist the profile through the sweep/extrude.
Obviously I can create a plane and sketch another hexagon in the correct orientation and then loft but that is a long way around to create a simple shape.
andrew_troup
Member, Mentor Posts: 1,585 ✭✭✭✭✭
There is currently no control over twist in the way you seek; the loft option is the way to go for now, but the program is evolving fast. You can vote for several levels of enhancement to sweep, including the exact one you identify here, by going to "Improvement Requests"1
Much appreciated.
The profile twist angle is equal to the angle between 2 planes.
Using Loft to eliminate the twist is unreasonable, when sweeping many sections.
There is no such problem with Pro-e.
OnShape has a way to go fixing many modeling issues. I am here only a couple of weeks and still learning how to use OnShape.
You fellows are great tying to help me with my assembly issue. All to no avail.
Why is it so difficult to recall parts into the assembly?
