Trying to Create a Simple Thin Extrude Remove on Feature Studio
jordan_karyanto374jordan_karyanto374 Member Posts: 4
edited January 2024 in FeatureScript
Hi everyone,
I am trying to create a custom feature that draw some sketches and extrude them as thin feature and removed it from the existing solid.
It is a simple thing to do with the built-in extrude feature, but I have been scratching my head on how to implement them in the feature studio.
I have been trying to use opExtrude, but that seem to not able to do thin feature, and the normal extrude function is not able to be pulled out in the feature studio.
Here are my existing code:
FeatureScript 2241; import(path : "onshape/std/common.fs", version : "2241.0");
annotation { "Feature Type Name" : "Fillet Cut2" }
export const Filletcut = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
        // annotation { "Name" : "Fillet Size" }
        // isLength(definition.filletSize, LENGTH_BOUNDS);
        // annotation { "Name" : "Side Length" }
        // isLength(definition.sideLength, LENGTH_BOUNDS);
        annotation { "Name" : "Plane", "Filter" : EntityType.FACE, "MaxNumberOfPicks" : 1 }
        definition.plane is Query;
        annotation { "Name" : "Top Point", "Filter" : EntityType.VERTEX, "MaxNumberOfPicks" : 1 }
        definition.pointT is Query;
        annotation { "Name" : "Right Point", "Filter" : EntityType.VERTEX, "MaxNumberOfPicks" : 1 }
        definition.pointS is Query;
        // Define the function's action
        // Create a plane at the top right corner of the selected face
        const facePlane = evFaceTangentPlane(context, {
                    "face" : definition.plane,
                    "parameter" : vector(1, 1) //This means that the plane will be at the top right corner 0,0 is the bottom left
        const pointT = definition.pointT;
        const pointS = definition.pointS;
        const custom_plane = definition.plane;
        const l_diff = 11.3 * sin(45 * degree);
        var sketch1 = newSketch(context, id + "sketch1", {
                "sketchPlane" : definition.plane
        // Create sketch entities here
        var rectangular1 = skRectangle(sketch1, "rectangle1", {
                "firstCorner" : vector(3, 0) * millimeter,
                "secondCorner" : vector(54.6, 51.6) * millimeter
        skArc(sketch1, "arc1", {
                    "start" : vector(3, 11.3) * millimeter,
                    "mid" : vector(14.3 - l_diff, 11.3 - l_diff) * millimeter,
                    "end" : vector(14.3, 0) * millimeter
        skArc(sketch1, "arc2", {
                    "start" : vector(3, 40.3) * millimeter,
                    "mid" : vector(14.3 - l_diff, 40.3 + l_diff) * millimeter,
                    "end" : vector(14.3, 51.6) * millimeter
        skArc(sketch1, "arc3", {
                    "start" : vector(43.3, 51.6) * millimeter,
                    "mid" : vector(43.3 + l_diff, 40.3 + l_diff) * millimeter,
                    "end" : vector(54.6, 40.3) * millimeter
        skArc(sketch1, "arc4", {
                    "start" : vector(54.6, 11.3) * millimeter,
                    "mid" : vector(43.3 + l_diff, 11.3 - l_diff) * millimeter,
                    "end" : vector(43.3, 0) * millimeter
        skSolve(sketch1);         // Here is where I struggle to turn the sketch above into thin extrude feature to remove it from the existing solid.  });
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,979 image
    You have to break it down into individual modelling steps. Extrude surface > thicken > remove > delete surface (that's what the built-in feature is doing). The tutorial does exactly that: https://cad.onshape.com/FsDoc/tutorials/create-a-slot-feature.html
  • jordan_karyanto374jordan_karyanto374 Member Posts: 4
    Thanks Neil!
    I will take a closer look. One quick question though. There are many entities on my sketch, how do I select the one I am interested to extrude as surface?
    sketchEntityQuery
