Driving Tool Path With Sketches
wayne_sauder
Member, csevp Posts: 646 PRO
in CAM Studio
I think we should have the ability to drive tool paths with sketches. It can be an easy way to force a cutter to do what needs to be done. One example would be the trochoidal tool path. I also think that this particular tool path should have an offset (if I try to use this to mill along the edge of a part I don't want the tool path centered on the edge). I may have missed something here.
We obviously want to support sketches directly. But because there is this workaround, we are working on other things first.
Let me know if that answer is not clear
I didn't think about trying a curve, I did discover I could use a surface as a work around.
it is a temporary workaround. Also chain/loop select is on the plan too
Joe
