Improvements to Onshape - January 12th, 2024
13»
  • eric_pestyeric_pesty Member Posts: 2,282 PRO
    edited January 2024
    @S1mon
    Interesting!
    Surely this suggests they will be adding the functionality to project onto arbitrary surfaces if it already works from a technical standpoint... I'm guessing it's just a matter of coming up with a user interface for it and getting feedback on the current version before expanding.
    I was also hoping it would translate to RenderStudio but I'm guessing that is also just a matter of time...
  • Marc_MillerMarc_Miller Member Posts: 110 ✭✭✭
    Cool find @S1mon and @romeograham. Yes, hopefully decals can further be improved.
    I also messed with using two transparent decals and they didn't overlap as I would have expected. The first one I applied was showing up on top of the second one.
  • Philip_Thomas_PTCPhilip_Thomas_PTC Member Posts: 11 PRO
    I take my eyes off this thread for 5 minutes and we have Beavis/ButtHead and people hot-wiring Onshape! :)
    Quick story - I wrote the original spec for decals in 2015 (or thereabouts), and it called for planar and cylindrical surfaces only because 'decals' (also known as 'appliques') was the original use case (other surface shapes cause the decals to physically wrinkle). The intent was never for decals to be a texturing tool or material representation. With the advent of PCB studio, being able to import an image of the board (or potentially even generate a trace image), became another use case that would work using just planar and cylindrical faces (including (should it ever happen), ribbon cables or other flexible circuits).
    Things I would like:
    1) To be a fly on the wall during the QA standup tomorrow morning!
    2) More importantly - If you believe that there is a use-case for decals on additional surface topologies that ISNT a shader or material/texture representation, then please open an enhancement request detailing the use-case.
    Thank you.
  • MichaelPascoeMichaelPascoe Member Posts: 2,482 PRO
    Nice find @romeograham!
  • S1monS1mon Member Posts: 3,447 PRO
    edited January 2024
    @Philip_Thomas_PTC
    I created an IR for 3D surfaces before @romeograham figured out the replace face hack.
    https://forum.onshape.com/discussion/22824/allow-decals-on-surfaces-with-3d-curvature
    As I mention in there, pad printing on consumer products which have some compound curvature is a really obvious example (at least in my experience), but also things like packaging with either labels that are developable surfaces (even if they're not cylindrical) or there are all kinds of graphics which are shrunk-wrapped or dipped onto products (hydrographics).
    Here's a pretty extreme example of pad printing on a soccer ball:
    https://www.youtube.com/watch?v=5gonNrmRnto
    Here's a shrink sleeve machine:
    Here's a production hydrographic line adding fake woodgrain to a plastic part:
    Here's another production hydrographic line adding graphics to vacuum bottles:
    There's also a related IR to add dimensions to locate the graphic on a drawing. That will likely be more complex, but typically what I've ended up doing is actually making a split surface or a very small extrusion or thickened area (~0.03 mm - roughly the thickness of the ink) so I have edges to attach dimensions to. That's assuming a single color thing which isn't too crazy to turn into geometry. It requires getting the graphic as an Illustrator file, converting to a DXF and scaling and locating it correctly. The actual graphic is always controlled by the Illustrator file if it's printed onto the product, but the 2D mechanical drawing controls the placement and tolerances.
  • rick_randallrick_randall Member Posts: 402 ✭✭✭
    Am I the only one thinking decals and cosmetic threads?
    @S1mon - Very helpful list and examples - thank you. More coming in the future :)
