Barrel Cam Issue with Wrap
Connor_LeCLaire
Member Posts: 33 ✭✭
Hi,
I am attempting to design a simple non-continuous barrel cam for an application. It has a straight section then a section that is at 30deg from the main axis of the cylinder, these are joined by a small circular curve tangent to each. I sketched the centerline, and used the Slot sketch feature to make it the correct width. Then used the wrap feature around the already-extruded cylinder, selected solid and remove. However, I noticed that the walls are tapered inwards (as if project from the center of the cylinder) and the bottom is also curved.
Current geometry using process above:
Desired geometry
The cam path
I've also tried using a projected curve with a swept profile. However the projected curve loses the constant pitch angle portion (30deg) as it deforms into being 90deg at the quarter-turn point. Then the sweep profile does not stay normal to the path.
The only thing I can think of is using a much more complex lofted profile with multiple planes, profiles, and guide curves which I'd like to avoid.
Desired geometry
The cam path
Sweeps can be tricky. Try using Ruled surface and Thicken.
Note: as far as I know, currently ruled surface must be from an edge that is attached to a face.
Here is an example of how you can do this:
https://cad.onshape.com/documents/64a2e109c70c8538267535cb/w/bca54bce48e1b9da3a877bf4/e/d6528b4752e98...
