How to Connect the sweep with out overlap?
joshua_swartz441joshua_swartz441 Member Posts: 7 EDU
edited January 2024 in Using Onshape
https://cad.onshape.com/documents/81b1f4a6579bdc76e6461bb1/w/e639ec34e3f175c39ed6a3f2/e/c9af096937ad79d6df755983?renderMode=0&uiState=65ad464fccb15e33e4e346ed
Hi I was wondering if there is a better way to make this heart shape other than using the sweep feature and if sweep is the best way how do I connect the parts without overlap?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,923 image
    Use sweep, but draw the centreline of the sweep not the outside. You could do it all in one feature without mirror.
