Move Face while keeping edges?
Andre_ComellaAndre_Comella Member Posts: 71 PRO
Hi all,
I'm trying to indent a the bottom of a part so I can create a drain hole. IN the image below, I'll eventually remove the center square. But I'd like the four trapezoids to all slope downwards at the center. My thought initially was to try splitting the face and trying to move that center square dozen in Z while somehow keeping the edges attached so that they all move with the face. Instead, move face will create new, vertical faces.
I'm also open to other suggestions here. I guess the broader question is how to create a pyramidal dent in a surface, particularly when there's no guarantee of symmetry.
  • S1monS1mon Member Posts: 3,797 PRO
    There are a lot of different ways to do this, but Loft/remove is probably the most straightforward.
  • Andre_ComellaAndre_Comella Member Posts: 71 PRO
    Thank you! As soon as you said this, it made perfect sense. Loft is one of those features I use so infrequently I forget about it.
