How to view and edit dimensions
Hello, I am new to Onshape and can not figure out how to show dimensions in the sketch view. I can see a dimension when I create something in sketch, but I am unable to modify those dimensions. I assuming I have some view option toggled off, but can not figure it out. I can edit a sketch and physically click and drag an object to change the dimension, but can not see a dimension, click on it, and change it.
Thank you,
Scott
Thank you,
Scott
Matt_Shields Member, Onshape Employees Posts: 651 EDU
The confusion might be coming from the fact that dimensions don't exist until you manually create them with the dimension tool.
https://cad.onshape.com/help/Content/sketch-tools-dimension.htm
1
