need help defining a formula value within a variable
I have this variable defined. As you can see I am using two other variable definitions to define the value of a third variable. As written it works just fine. Im taking the #slat_width multiplying by a factor of .87 and then dividing by the #slat_slot_count to define the #slat_slot_distance.
What I NEED to do instead is subtract a value (70) from #slat_width variable then divide it by the #slat_slot_count variable.
However when I replace the multiple (*) with the subtract (-) operator it fails. What am I doing wrong/how do I fix this?
MichaelPascoe Member Posts: 2,307 PRO
For multiplication and division, you can multiply a (value with units) by a (unitless value): 45in * 4
However, for addition and subtraction, both values need to have similar units: 45in - 5m
So you could not do:
45in - 5
45in - 5in^2
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴0
45in - 5
45in - 5in^2
