Onshape, it can calculate a surface of 2D (rectangle,...)?
achref_hciniachref_hcini Member Posts: 2
Onshape, it can calculate a surface of 2D (rectangle,circle,...)?
  • Narayan_KNarayan_K Member Posts: 379 ✭✭✭
    achref_hcini, As i understand,you want to find area of rectangle or circle in Onshape.If so then it is possible.Just click on the closed face of the rectangle/circle.you can find the area at the measurement box provided at the right bottom side of the window.
    @achref_hcini , User can get surface area for rectangle and circle by clicking on respective face as shown in below video.
    @viru A side bar... what are you using to capture gif animations?
    @pete_yodis , i am using licecap tool by adjusting browser window by dragging
    Thanks... I think that is what others here have mentioned.  I'll need to put it on my to do list.  Kind regards...
  • achref_hciniachref_hcini Member Posts: 2
    @viru  , @Narayan_K  thank you  :)
