1in/2.5in=0.4mm
ProApeProApe Member Posts: 52
Hello,
I am working in mm
I have defined 2 variables: I enter:
#width: 1in, will be converted to mm: 25.4mm
#devider: 2.5in, is converted to mm: 63.5mm
If I then define the length of a line: #width/#devider, I get 0.4mm instead of 0.4in converted to mm!
What am I doing wrong?
Kind regards
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,428
    Dividing inches by inches results in no units at all so it is 0.4 x your units (mm). Therefore divide the two values and multiply by the units you want (#width/#devider) * inch
    ok, thank you!
