Unable to extrude sketch
Hello,
I'm relatively new to CAD modeling and Onshape. Currently, I'm working on modifying an adapter to suit my requirements.
In the provided project link, my objective is to extrude (cut) "Sketch 1" from "Part 1" and replace the removed section with "Part 2". It's worth noting that "Part 2" was created using the extrude "New" feature using a vertex. Currently, I can only use "New" with the extrude on my "Sketch 1".
Here's a clearer breakdown of what I aim to achieve:
1. Extrude "Sketch 1" to a thickness of 2.5mm (if possible).
2. Rotate the extruded part by 180 degrees.
3. Union the two resulting parts together.
Feel free to ask questions if I make myself unclear.
I'm wondering if there's a simpler way to accomplish this task. You can access the project through the following link:
Improvements to Onshape - April 25th, 2022 — Onshape
https://cad.onshape.com/documents/6bb1a219f659f777afcda948/w/2d33793328c74f43788ed011/e/deeea2a982206634a8e7576c?renderMode=0&uiState=65b68e8b275b086e44b6d044
For this one I have a video and hope this will make things clearer.
https://streamable.com/i0yt7e
