Simple Question --- how to remove at an angle?
louis_minottilouis_minotti Member Posts: 1 ✭✭
For the image below, while I have used SolidWorks & related many years ago, how to best extrude that circle shown at an angle going slightly down to the given plane  which it exists upon the as seen while using Onshape?
Yes, this is a remove operation.  Though, for what is shown below with respect to that circle, what is the best way for this to be performed?  What features/operations with Onshape do I need to engage with?
Thank you.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,970 image
    Same as SolidWorks really. Either Sweep or Extrude with direction. Either way you’ll need to create a path (with a sketch) to define the direction.
