Bending a shape
in General
Here's a 3D model I found. It is full of errors, such as non-manifold edges, so I can't use it. But I'm trying to make my own version.
So I drew the following 2D image and extruded it, Now I want to bend it into a leaf shape. Exploring the documentation does not make the means of doing this obvious. A pointer to the primitives I need or a tutorial are what I need. Note that I will probably make six different leaves and create an assembly, which will also have a base for a lamp at the bottom. TIA.
I tried going to sheet metal, using just the sketch (not the extruded component) but I couldn't figure out how to put a flange in at a certain line across the narrow part.
From there, you can use the Rollback Bar to review it step by step.
