How to emboss a logo to a non planar object
Eric_92
OS Professional Posts: 22 PRO
Ok this is something there has got to be an easy workflow too but I spent about an hour researching feature scripts and could not find a good match.
Say we have an injection molded part with an irregular surface and we want to lightly emboss a logo to it.
The only way I was able to get this to work was to do a removal extrude at a uniform depth greater than intended. Then after that sketch in a "Fill" profile and extrude within the part to fill back to get the depth of the emboss to be uniform through the curves.
It works but not the cleanest workflow... Thanks!
S1mon
Member Posts: 3,777 PRO
I was able to do this with your sample, but only if I moved the logo slightly so that the corners weren't so close to the joints of the surfaces.
Tinkered with these suggestions but not figuring it out.
Here is the sample public document:
https://cad.onshape.com/documents/e417bd07e64a9b6a44f6233c/w/bad6d5dd99a61fb86fb2a595/e/f241b0d238817f1eb0e1a0b0
