Adjust Sheet Metal Rip from Edge Joint to Butt Joint
daniel_pinto240
Member Posts: 6 PRO
I want the top sheet metal surface of this part to meet the side faces in a butt joint style, but the sheet metal command has no option to do this, and the Joint command is not allowed on previously created joints.
Grrr. I can do it with an extrude, but then it doesn't show up in the flat pattern. Any tips?
You can see my failed joint, and my $hi77y extrude.
eric_pesty
Member, pcbaevp Posts: 2,583 PRO
Open the bend table on the right, this is where you can change existing joints between rip/but and other but direction:daniel_pinto240 said:I want the top sheet metal surface of this part to meet the side faces in a butt joint style, but the sheet metal command has no option to do this, and the Joint command is not allowed on previously created joints.Grrr. I can do it with an extrude, but then it doesn't show up in the flat pattern. Any tips?You can see my failed joint, and my $hi77y extrude.
If for some reason that doesn't work, move face is the best alternate way to achieve this. I suggest playing with the move face in sheet metal, it works really well...2
I wish there was a cleaner way to do this but the best method I found is the move-face command. You will need to leave a small gap between faces to get the sheet metal tools to unfold correctly.
I would start by pushing the face you want underneath back 2 to 5 thousandths then you should be able to pull the other face overtop.
