Decals coming in backwards in Render Studi
dave_franchinodave_franchino Member Posts: 74 ✭✭
Hey folks, I'm trying to learn render studio and it's been a bit of a slog.  My latest issue surrounds applying "stickers"
A) It appears as if "decals" applied in a part studio do not translate into render studio and need to be re-applied. Is this correct?
B) Whenever I am applying a sticker it is coming in "flipped" or backwards.  I don't see a way to correct this?
Desired:
Result:
C) My stickers are not centered the way I want them to be but entering numbers into "offset" don't appear to do anything
Any hints?
Thanks!
Dave
  • Cary_BettenhausenCary_Bettenhausen Member Posts: 48 PRO
    edited February 2024
    I'm seeing the same behavior when applying deals to surfaces. They are flipped with no way to reverse them. I filed a support ticket the day Decals were released.
  • Paul_ArdenPaul_Arden Member, Onshape Employees, Developers Posts: 225 image
    @dave_franchino You are correct, currently decals are not taken over from Part Studios into Render Studios. For the issue of the flipped sticker, one trick (which I admit is not so intuitive) is to use a negative tiling factor (below the Offset option you circled). So in your case you'd want to change the tiling from 1,1 to -1,1 to flip it horizontally (to flip vertically if needed you would use 1,-1).
