How to stretch part diagonally
thomas_fieguth
Member Posts: 3 EDU
Is there a way to have a part and then shift one side down to change the part? For example, if you have an extruded rectangle, could you shift one side down to transform it into an extruded parallelogram (as shown in the picture below)? I cannot do this in the sketching part of the design. Any help is much appreciated.
matthew_stacy
Member Posts: 489 PRO
@thomas_fieguth, the "Move Face" tool will accomplish the task that you describe (example):- Select top and bottom faces of the Part
- Select ROTATE (alternates OFFSET & TRANSLATE)
- Select an AXIS to rotate about
- Specify the ANGLE of rotation (and direction)
However I encourage you to question your assertion that, "I cannot do this in the sketching part of the design". Editing the sketch, is generally the superior method and a better modeling practice.- Delete the HORIZONTAL constraint (top of rectangle)
- Delete PERPENDICULAR constraint
- Drag the rectangle into a parallelogram. Better yet dimension the angle, to fully constrain the sketch (good engineering practice)
1
Have a look at the help file.
https://cad.onshape.com/help/Content/constraints.htm?Highlight=Constraints
But it will be much easier to draw the sketch with an angle in the first place, define the angle and can change it whenever you want
I should have been more specific about the "I cannot do this in the sketching part of the design" statement. The example I gave was an oversimplification of my problem for the sake of clarity.
