Export feature
scott_geramiscott_gerami Member Posts: 5
Hello! I designed a part today and I am not able to export it? I get the export menu like I have in the past but after I hit export nothing happens? It worked the other day? If you have any ideas what the issue is I would appreciate some assistance. Scott
  • _anton_anton Member, Onshape Employees Posts: 444
    All looks fine. The file's not downloading? You don't need to select everything; can you right-click on "Part 1" in the parts list on the left, click "Export...", and see if the problem persists?
    Can you share the document or a screenshot of your export dialog?
  • scott_geramiscott_gerami Member Posts: 5
     I hope this helps?
    Thanks for helping. It is working now? I had an appointment and came back and it works now? Maybe there was a system issue.  Scott
